networkPort.ipv6PrefixLength |
Indicates the length in bits of the subnet prefix of the IPv6 address of this network port. The value of this property shall be in the range 1 to 128. If the IPv6 address is obtained automatically, this property shall be read-only.
Property ipv6PrefixLength of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.ipv6PrefixLength |
<type> = 56 |
<property> = 437 |
An 8-bit integer value ranging from 0 to 255.
