networkPort.ipv6DhcpLeaseTime |
Indicates the lease time in seconds of the last DHCPv6 lease obtained for the port. If IPv6_Auto_Addressing_Enable is FALSE, or DHCPv6 is not in use, or no lease has been acquired, or the value is unknown, this property shall be 0.
Property ipv6DhcpLeaseTime of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.ipv6DhcpLeaseTime |
<type> = 56 |
<property> = 443 |
A 32-bit unsigned integer.
