networkPort.ipv6DefaultGateway |
Indicates the IPv6 address of the default gateway for this network. This property shall be conveyed with the most significant octet first. If the IPv6 address is obtained automatically, this property shall be read-only.
Property ipv6DefaultGateway of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.ipv6DefaultGateway |
<type> = 56 |
<property> = 439 |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A').
