networkPort.ipv6Address |
Indicates the IPv6 address of this network port. This property shall be conveyed most significant octet first. If the IPv6 address is obtained automatically, this property shall be read-only, and the value of this property shall contain the address with the highest precedence.
Property ipv6Address of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.ipv6Address |
<type> = 56 |
<property> = 436 |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A').
