networkPort.ipSubnetMask |
Indicates the subnet mask for this network. This property shall be conveyed with the most significant octet first. If the IP_DHCP_Enable property is TRUE, this property shall be read-only.
Property ipSubnetMask of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.ipSubnetMask |
<type> = 56 |
<property> = 411 |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A').
