networkPort.ipDhcpServer |
Indicates the address of the DHCP server from which the last DHCP lease was obtained for the port. If the address of the DHCP server cannot be determined, the value of this property shall be X'00000000'.
Property ipDhcpServer of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.ipDhcpServer |
<type> = 56 |
<property> = 405 |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A').
