networkPort.ipDhcpLeaseTime |
Indicates the lease time in seconds of the last DHCP lease obtained for the port. If IP_DHCP_Enable is FALSE, or no lease has been acquired, or the value is unknown, this property shall be 0.
Property ipDhcpLeaseTime of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.ipDhcpLeaseTime |
<type> = 56 |
<property> = 403 |
A 32-bit unsigned integer.
