networkPort.ipDhcpEnable |
Indicates whether or not this network is configured via DHCP. A value of TRUE indicates that DHCP configuration is enabled, FALSE indicates it is not. This property is required if DHCP configuration is supported by this network port.
Property ipDhcpEnable of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.ipDhcpEnable |
<type> = 56 |
<property> = 402 |
