networkPort.ipAddress |
Indicates the nominal power consumption of the load(s) controlled by this object at this moment. The units shall be kilowatts.
Property ipAddress of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.ipAddress |
<type> = 56 |
<property> = 400 |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A').
