networkPort.fdSubscriptionLifetime |
Indicates the Time-To-Live value, in seconds, to be used in the Register-Foreign-Device BVLL message. This property shall be present and writable if BACnet_IP_Mode is FOREIGN.
Property fdSubscriptionLifetime of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.fdSubscriptionLifetime |
<type> = 56 |
<property> = 419 |
A 16-bit integer value ranging from 0 to 65535.
