networkPort.command |
Used to request that the Network Port object perform various actions.
Property command of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.command |
<type> = 56 |
<property> = 417 |
An integer representing one of the options of enumeration <BACnetNetworkPortCommand>.
