networkPort.bacnetIpv6UdpPort |
Indicates the BACnet/IPv6 UDP port number of this network port.
Property bacnetIpv6UdpPort of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.bacnetIpv6UdpPort |
<type> = 56 |
<property> = 438 |
A 16-bit integer value ranging from 0 to 65535.
