networkPort.bacnetIpv6MulticastAddress |
Contains the IPv6 multicast address UDP port to be used for the distribution of BACnet broadcast messages in the local multicast domain. The value of this property shall be comprised of the IPv6 multicast address followed by the UDP port, both of which shall be conveyed with the most significant octet first.
Property bacnetIpv6MulticastAddress of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.bacnetIpv6MulticastAddress |
<type> = 56 |
<property> = 440 |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A').
