networkPort.bacnetIpNatTraversal |
Indicates whether (TRUE) or not (FALSE) this port is configured to operate in a NAT environment, and the global address is indicated by the value of the BACnet_IP_Global_Address property.
Property bacnetIpNatTraversal of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.bacnetIpNatTraversal |
<type> = 56 |
<property> = 410 |
