networkPort.bacnetIpMulticastAddress |
Contains the BACnet/IP multicast group address to be used for the distribution of BACnet broadcast messages. The value of this property shall be conveyed with the most significant octet first. A value of X'00000000' indicates that BACnet/IP multicast is not used.
Property bacnetIpMulticastAddress of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.bacnetIpMulticastAddress |
<type> = 56 |
<property> = 409 |
A string value representing a sequence of octets, where each octet is represented by a pair of hexadecimal characters (ex: '0F121A').
