networkPort.apduLength |
Indicates the maximum number of octets that may be contained in a single indivisible application protocol data unit sent or received on this port. The value of this property shall be greater than or equal to 50. This property also indicates the maximum number of octets that may be contained in a single individual network service data unit sent or received on this port.
Property apduLength of object networkPort can be read and written using a single IOTag.
networkPort-<objectAddress>.apduLength |
<type> = 56 |
<property> = 399 |
A 32-bit unsigned integer.
