multiStateOutput.feedbackValue |
Indicates the status of a feedback value from which the presentValue must differ before an event is generated.
Property feedbackValue of object multiStateOutput can be read and written using a single IOTag.
multiStateOutput-<objectAddress>.feedbackValue |
<type> = 14 |
<property> = 40 |
A 32-bit unsigned integer.
