multiStateInput.reliabilityEvaluationInhibit |
Indicates whether (TRUE) or not (FALSE) reliability-evaluation is disabled in the object. This property is a runtime override that allows temporary disabling of reliability-evaluation. When reliability-evaluation is disabled, the Reliability property shall have the value NO_FAULT_DETECTED unless Out_Of_Service is TRUE and an alternate value has been written to the Reliability property.
Property reliabilityEvaluationInhibit of object multiStateInput can be read and written using a single IOTag.
multiStateInput-<objectAddress>.reliabilityEvaluationInhibit |
<type> = 13 |
<property> = 357 |
