multiStateInput.faultValues |
Specifies any states the presentValue must equal before a TO-FAULT event is generated.
Property faultValues of object multiStateInput can be read and written using a single IOTag.
multiStateInput-<objectAddress>.faultValues |
<type> = 13 |
<property> = 39 |
A character string containing an XML with a value of type <SequenceOfUnsigned>.
