loop.setpointReference
List of references that has a length of zero or one, indicating if the setpoint for this control loop is fixed and contained in the Setpoint property, or a property of another object.
Property setpointReference of object loop can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
loop-<objectAddress>.setpointReference
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 12
N3:
<objectAddress>
N4:
<property> = 109
Tag Value
A block where each element maps to a structure member.
•A string representing an object and a property in the syntax: '<objectType>-<objectAddress>.<property>'. An optional array index '(<index>)' can be used on array properties.OBS: this is an optional element, a <null> value indicates the element is not present.
