loop.proportionalConstant |
The value of the proportional gain parameter used by the loop algorithm.
Property proportionalConstant of object loop can be read and written using a single IOTag.
loop-<objectAddress>.proportionalConstant |
<type> = 12 |
<property> = 93 |
A 32-bit floating point number.
