loop.minimumOutput |
The minimum value of the presentValue property as limited by the loop algorithm.
Property minimumOutput of object loop can be read and written using a single IOTag.
loop-<objectAddress>.minimumOutput |
<type> = 12 |
<property> = 68 |
A 32-bit floating point number.
