loop.maximumOutput |
The maximum value of the presentValue property as limited by the PID loop algorithm.
Property maximumOutput of object loop can be read and written using a single IOTag.
loop-<objectAddress>.maximumOutput |
<type> = 12 |
<property> = 61 |
A 32-bit floating point number.
