loop.manipulatedVariableReference |
Identifies a property of an object which receives the output of the control loop.
Property manipulatedVariableReference of object loop can be read and written using a single IOTag.
loop-<objectAddress>.manipulatedVariableReference |
<type> = 12 |
<property> = 60 |
A string representing an object and a property in the syntax: '<objectType>-<objectAddress>.<property>'. An optional array index '(<index>)' can be used on array properties.
