loop.lowDiffLimit
loop.lowDiffLimit
Indicates the pLowDiffLimit parameter for the object's FLOATING_LIMIT event algorithm if it has a value other than NULL.
Property lowDiffLimit of object loop can be read and written using a single IOTag.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
loop-<objectAddress>.lowDiffLimit
Numeric Parameters
Property
Value
N1:
<deviceAddress>
N2:
<type> = 12
N3:
<objectAddress>
N4:
<property> = 390
Tag Value
•A null/empty value.
•A 32-bit floating point number.
