loop.integralConstant |
The value of the integral gain parameter used by the loop algorithm.
Property integralConstant of object loop can be read and written using a single IOTag.
loop-<objectAddress>.integralConstant |
<type> = 12 |
<property> = 49 |
A 32-bit floating point number.
