loop.errorLimit |
Conveys the absolute magnitude that the difference between the Setpoint and controlledVariableValue (the Error) must exceed before a TO-OFFNORMAL event is generated.
Property errorLimit of object loop can be read and written using a single IOTag.
loop-<objectAddress>.errorLimit |
<type> = 12 |
<property> = 34 |
A 32-bit floating point number.
