loop.derivativeConstant |
The value of the derivative gain parameter used by the loop algorithm.
Property derivativeConstant of object loop can be read and written using a single IOTag.
loop-<objectAddress>.derivativeConstant |
<type> = 12 |
<property> = 26 |
A 32-bit floating point number.
