loop.controlledVariableReference |
Identifies the property used to set the controlledVariableValue property of the Loop object.
Property controlledVariableReference of object loop can be read and written using a single IOTag.
loop-<objectAddress>.controlledVariableReference |
<type> = 12 |
<property> = 19 |
A string representing an object and a property in the syntax: '<objectType>-<objectAddress>.<property>'. An optional array index '(<index>)' can be used on array properties.
