loop.bias |
The bias value used by the loop algorithm expressed in units of the outputUnits property.
Property bias of object loop can be read and written using a single IOTag.
loop-<objectAddress>.bias |
<type> = 12 |
<property> = 14 |
A 32-bit floating point number.
