lightingOutput.power |
Indicates the nominal power consumption of the load(s) controlled by this object when the light level is 100.0% of the non-normalized range. The units shall be kilowatts.
Property power of object lightingOutput can be read and written using a single IOTag.
lightingOutput-<objectAddress>.power |
<type> = 54 |
<property> = 384 |
A 32-bit floating point number.
