lightingOutput.outOfService |
Indicates weather (TRUE) or not (FALSE) the physical input that the object represents is not in service.
Property outOfService of object lightingOutput can be read and written using a single IOTag.
lightingOutput-<objectAddress>.outOfService |
<type> = 54 |
<property> = 81 |
