lightingOutput.minActualValue |
Specifies the physical output level that corresponds to a Present_Value of 1.0%. Changing Min_Actual_Value to a value greater than Max_Actual_Value shall force Max_Actual_Value to become equal to Min_Actual_Value. Min_Actual_Value shall always be a positive number in the range 1.0% to 100.0%.
Property minActualValue of object lightingOutput can be read and written using a single IOTag.
lightingOutput-<objectAddress>.minActualValue |
<type> = 54 |
<property> = 383 |
A 32-bit floating point number.
