lightingOutput.maxActualValue |
Specifies the physical output level that corresponds to a Present_Value of 100.0%. Changing Max_Actual_Value to a value less than Min_Actual_Value shall force Min_Actual_Value to become equal to Max_Actual_Value. Max_Actual_Value shall always be a positive number in the range 1.0% to 100.0%.
Property maxActualValue of object lightingOutput can be read and written using a single IOTag.
lightingOutput-<objectAddress>.maxActualValue |
<type> = 54 |
<property> = 382 |
A 32-bit floating point number.
