lightingOutput.lightingCommandDefaultPriority |
Specifies a write priority of 1 to 16 that indicates the element of the Priority_Array controlled by the Lighting_Command property when the BACnetLightingCommand priority field is absent. The priority value 6 shall not be used for this property.
Property lightingCommandDefaultPriority of object lightingOutput can be read and written using a single IOTag.
lightingOutput-<objectAddress>.lightingCommandDefaultPriority |
<type> = 54 |
<property> = 381 |
A 32-bit unsigned integer.
