lightingOutput.instantaneousPower |
Conveys the nominal power consumption of the load(s) controlled by this object at this moment. The units shall be kilowatts.
Property instantaneousPower of object lightingOutput can be read and written using a single IOTag.
lightingOutput-<objectAddress>.instantaneousPower |
<type> = 54 |
<property> = 379 |
A 32-bit floating point number.
