lightingOutput.egressTime |
specifies the egress time in seconds when a WARN_RELINQUISH or WARN_OFF is written to the Lighting_Command property or when the special values -2.0 or -3.0 are written to the Present_Value property. The egress time is the time for which the light level is held at its current level before it is relinquished or set to 0.0%.
Property egressTime of object lightingOutput can be read and written using a single IOTag.
lightingOutput-<objectAddress>.egressTime |
<type> = 54 |
<property> = 377 |
A 32-bit unsigned integer.
