lightingOutput.defaultStepIncrement |
Indicates the amount to be added to the Tracking_Value when the Lighting_Command property is written with a step request that does not include a step-increment value. The range of allowable values is 0.1% to 100.0% inclusive.
Property defaultStepIncrement of object lightingOutput can be read and written using a single IOTag.
lightingOutput-<objectAddress>.defaultStepIncrement |
<type> = 54 |
<property> = 376 |
A 32-bit floating point number.
