lightingOutput.defaultRampRate |
Indicates the rate in percent-per-second at which changes to the normalized value reflected in the Tracking_Value property of the lighting output shall occur when the Lighting_Command property is written with a ramp request that does not include a ramp-rate value. The range of allowable ramp-rate values is 0.1 %/s to 100.0 %/s inclusive.
Property defaultRampRate of object lightingOutput can be read and written using a single IOTag.
lightingOutput-<objectAddress>.defaultRampRate |
<type> = 54 |
<property> = 375 |
A 32-bit floating point number.
