lightingOutput.defaultFadeTime |
Indicates the amount of time in milliseconds over which changes to the normalized value reflected in the Tracking_Value property of the lighting output shall occur when the Lighting_Command property is written with a fade request that does not include a fade-time value. The range of allowable fade-time values is 100 ms to 86400000 ms (1 day) inclusive.
Property defaultFadeTime of object lightingOutput can be read and written using a single IOTag.
lightingOutput-<objectAddress>.defaultFadeTime |
<type> = 54 |
<property> = 374 |
A 32-bit unsigned integer.
