lightingOutput.commandTimeArray
Indicates the time at which each priority was last commanded or relinquished.
Property commandTimeArray of object lightingOutput can be read and written using a block tag with 16 elements.
Text Parameters
Property
Value
ParamDevice
<deviceAddress>
ParamItem
lightingOutput-<objectAddress>.commandTimeArray
Size
16 elements
Numeric Parameters
Property
Value
B1:
<deviceAddress>
B2:
<type> = 54
B3:
<objectAddress>
B4:
<property> = 430
Size:
16 elements
Block Elements
Index
Name
Type
0
elm00
A Date, Integer, Null or String (Xml) value representing a timestamp in BACnet.
•A null value means the timestamp is empty/not set;
•A date/time value representing a precise date and time;
•An integer defining the timestamp sequence number;
•A character string containing an XML with a value of type <BACnetTimeStamp>.
1
elm01
2
elm02
3
elm03
4
elm04
5
elm05
6
elm06
7
elm07
8
elm08
9
elm09
10
elm10
11
elm11
12
elm12
13
elm13
14
elm14
15
elm15
