lift.objectIdentifier |
Property objectIdentifier of object lift can be read and written using a single IOTag.
lift-<objectAddress>.objectIdentifier |
<type> = 59 |
<property> = 75 |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345').
