lift.nextStoppingFloor |
Indicates the universal floor number where the car will stop next when underway. If the car is not in motion, this property indicates the current universal floor number.
Property nextStoppingFloor of object lift can be read and written using a single IOTag.
lift-<objectAddress>.nextStoppingFloor |
<type> = 59 |
<property> = 476 |
An 8-bit integer value ranging from 0 to 255.
