lift.lowerDeck |
References the Lift object that is representing the car deck below the car deck represented by this object. If this property is present, and there is no lower deck, then the object instance shall be 4194303.
Property lowerDeck of object lift can be read and written using a single IOTag.
lift-<objectAddress>.lowerDeck |
<type> = 59 |
<property> = 473 |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345').
