lift.installationId |
Represents the identification number for the lift represented by this object. This identification number shall be unique for the lift in this group, but might not be otherwise unique for other lifts in the machine room or the building.
Property installationId of object lift can be read and written using a single IOTag.
lift-<objectAddress>.installationId |
<type> = 59 |
<property> = 469 |
An 8-bit integer value ranging from 0 to 255.
