lift.higherDeck |
References the Lift object that is representing the car deck above the car deck represented by this object. If this property is present, and there is no higher deck, then the object instance shall be 4194303.
Property higherDeck of object lift can be read and written using a single IOTag.
lift-<objectAddress>.higherDeck |
<type> = 59 |
<property> = 468 |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345').
