lift.energyMeterRef |
References the object which indicates the accumulated energy consumption by the lift.
Property energyMeterRef of object lift can be read and written using a block tag with 2 elements.
lift-<objectAddress>.energyMeterRef |
Size |
2 elements |
B1: |
B2: |
<type> = 59 |
B3: |
B4: |
<property> = 461 |
2 elements |
Index |
Name |
Type |
0 |
DeviceIdentifier |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345'). OBS: this is an optional element, a <null> value indicates the element is not present. |
1 |
ObjectIdentifier |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345'). |
