lift.elevatorGroup |
References the Elevator Group object whose Group_Members property contains a reference to this Lift object. If there is no such Elevator Group object, this property shall contain an object instance of 4194303.
Property elevatorGroup of object lift can be read and written using a single IOTag.
lift-<objectAddress>.elevatorGroup |
<type> = 59 |
<property> = 459 |
A string value containing a BACnet Object Identifier in the syntax '<Type>-<Address>' (ex: 'analogOutput-345').
