lift.carMovingDirection |
Represents whether or not this lift's car is moving, and if so, in which direction.
Property carMovingDirection of object lift can be read and written using a single IOTag.
lift-<objectAddress>.carMovingDirection |
<type> = 59 |
<property> = 457 |
An integer representing one of the options of enumeration <BACnetLiftCarDirection>.
