lift.carLoad |
Indicates the load in the car, both passengers and goods. The value of the Car_Load property shall be in units as indicated by the Car_Load_Units property.
Property carLoad of object lift can be read and written using a single IOTag.
lift-<objectAddress>.carLoad |
<type> = 59 |
<property> = 454 |
A 32-bit floating point number.
